Author Topic: Duro Battery plier  (Read 9671 times)
Duro Battery plier
« on: August 17, 2011, 03:09:42 PM »
 Got a pair of Duro(mark not legible) but design pat # 119441 is stamped on face of plier. Alloy shows similar pair with this patent and model # 2114. This pair has model # 7505 on face. Whats the difference ? Did they make these with different size box ends. This pair has 9/16 and 5/8 box ends. Alloy doesn't say what size ends on 2114 are.
 These were beyond restoration when I got them,but a vinegar bath and a little buffing got them in usable if not collectible shape.
Re: Duro Battery plier
« Reply #1 on: August 17, 2011, 04:18:41 PM »
There could be different versions I suppose, the terminals on large batteries have bigger bolts in them....
Never thought about that one before....hmm...
Offline eddie hudson
  • NYC
« Reply #2 on: August 17, 2011, 05:44:52 PM »
There is a # 2115 battery plier on page 18 of the 1935 Duro catalog, but it looks nothing like yours.
Offline ToolsorDie
« Reply #3 on: September 03, 2011, 07:13:24 PM »
Duro-Chrome 2114 Battery Pliers, Patent #D119,441
Found on this page, exact match.  http://home.comcast.net/~alloy-artifacts/duro-indestro-p2.html
Looks like the ends of the handles were box wrenches
Offline 64longstep/Brian
  • Phoenix Arizona
« Reply #4 on: September 03, 2011, 08:28:37 PM »
I’ve seen a pair like those…  I like them...
« Reply #5 on: September 04, 2011, 01:49:46 PM »
  my question is what is difference between model 2114 and 7505 ?
Offline ToolsorDie
« Reply #6 on: September 04, 2011, 01:58:27 PM »
Looks like none, some manufacturers change part numbers when upgrading their numbering system.
« Reply #7 on: February 23, 2015, 05:08:43 PM »
I just scored a pair marked Belden. Model 7505 with the same design patent. Now for some clean-up.
« Reply #8 on: February 23, 2015, 05:42:44 PM »
I try to use the least invasive cleaning possible, and on these pliers, I just used some SS Steel wool. Not bad results, huh?
Now, if I get out to the shop tomorrow, I might wire wheel them a bit.
By the way, the box ends are 9/16 and 5/8.
« Last Edit: February 23, 2015, 05:46:21 PM by Papaw »
« Reply #9 on: February 23, 2015, 06:11:20 PM »
Not bad. Do you figure that's chrome plating on them, or nickel?
« Reply #10 on: February 23, 2015, 06:24:32 PM »
If plated at all, it is nickel. Pliers are made of Chrome Vanadium Steel, not to be confused with chrome plating.
The similar Duro #2115 seen in Alloy Artifacts is cadmium plated. Sure these are not.
https://home.comcast.net/~alloy-artifacts/duro-indestro-p4.html
Online Yadda
« Reply #11 on: February 23, 2015, 11:14:09 PM »
Saw  a pair of these on the bay.  Neat tool.
« Reply #12 on: February 24, 2015, 10:13:46 PM »
Never owned or seen a pair like that.  I have 4 pair of batt. pliers, but believe those would be handy, especially working on the old stuff.
« Reply #13 on: February 26, 2015, 09:59:32 PM »
What sizes are the 12 pt box ends?
« Reply #14 on: February 26, 2015, 11:06:54 PM »
Quote
