Author Topic: What's the deal with this arbor press?  (Read 7268 times)
Re: What's the deal with this arbor press?
« Reply #15 on: August 11, 2014, 03:09:07 AM »
Also need to consider the square inch of press...  2 tons over 1 Square inch isn't hard, considering a high heal shoe spike can apply ~1 ton pressure over 1/4" sq.....
In this case it is quite a lot.
I don't understand the high heel analogy, could you help me? Is the wearer very large, or are you referring to stomping or something like that?
Offline Twilight Fenrir
« Reply #16 on: August 11, 2014, 07:01:19 AM »
Well, that's a bit of an exaggeration, but right in principle...
If a person weighs 200 lbs is standing on 1/4" spike, that's 800 psi. Doesn't quite work out that way, because SOME weight is on the front of the shoe, and there are two heels. If you narrowed the heel down to a real spike, pointy and all, could clear 2k psi easily, I suspect.
« Reply #17 on: August 11, 2014, 09:52:30 PM »
Yes, but to show the "point", that you Also need to consider the "square inch of press" are you pressing more than 1" square? or less
1" sq. is 16 1/4" sq. ( 4X4), so 16 X 200 is 3200#, (granted she is standing on 1 heel.)  something to think about...
« Reply #18 on: August 11, 2014, 10:09:21 PM »
.... Right you are... I never did do very well in geometry XD Could throw algebra at me all day long, but for some reason, geometry just never stuck...
« Reply #19 on: August 12, 2014, 01:13:29 AM »
Except, gentlemen, psi isn't relative to the presses rating or to the way it increases power.
It is two different concepts and isn't usually used when talking about this type of work /tool.
If you are talking hydraulics, especially closed systems, then we are in business. And I can help a lot there. Thats what I get paid to do.  Well, that and being eye candy.
