Author Topic: Wedge shaped hammer  (Read 6652 times)
Offline RedVise
Wedge shaped hammer
« on: May 11, 2014, 03:46:06 PM »
Picked up a wedge shaped hammer this weekend.
Looks like it is from Worcester , Company name looks like St something,
and the patent date is not clear either.
Note the hole running thru the head...
Any clues on this one ?
Brian
Also neat oil can and more chisels, one from Sheffield.
Re: Wedge shaped hammer
« Reply #1 on: May 11, 2014, 06:45:19 PM »
Weird. Don't know of any hammer makers in Worcester.
Long wedge, long handle, uselessly short head, makes me think tire bead breaker..
Vaguely like 2525429
Offline RedVise
« Reply #2 on: May 11, 2014, 08:55:31 PM »
Looks like it is from St Pierre MFG  , located in Worcester MA.
Brian
« Reply #3 on: May 11, 2014, 09:06:22 PM »
>St Pierre MFG  .
Used to make chain...
Hmm, perhaps a (big) chain breaker?
« Reply #4 on: May 12, 2014, 07:39:12 AM »
Got two of these, both of which have been kept sharp, and work at the forge as chisels.  In fact, one came with a bunch of tools I bought from an old blacksmith.
Offline RedVise
« Reply #5 on: May 12, 2014, 08:17:41 AM »
Branson, mine is small. They work as chisels ?  Obviously I have no metal work background...
Brian
« Reply #6 on: May 12, 2014, 09:35:01 AM »
St. Pierre made tire chain pliers along with the chains.  Maybe these were used on really big chains instead of the pliers.
« Reply #7 on: May 12, 2014, 11:43:37 AM »
To me they look like a smallish version of a Blacksmith's cutter or cutoff tool it would be struck by another larger hammer. so a chain cutter is possible.
« Reply #8 on: May 13, 2014, 07:32:43 AM »
Brian
Mine are small, too.  So were the chisels issued with the mountain howitzer -- in fact, about the same size.
Offline RedVise
« Reply #9 on: May 13, 2014, 07:54:38 AM »
Thanks for the info guys!  Now, about that hole in the other end of the hammer... ?
I will try and clean it out tonight.
Brian
PS: them smileys aint doing much for me...
« Reply #10 on: May 14, 2014, 07:33:42 AM »
Brian
Why, so you can put it on a chain and wear it as a pendent, of course.
Dunno, mine have the hole, too.
« Reply #11 on: May 14, 2014, 04:07:39 PM »
Hole for pin to hold on replaceable face?
Offline bear_man
« Reply #12 on: June 04, 2014, 02:22:42 AM »
I agree with it being a blacksmith's cutting tool, but whether for "hot work" or "cold," I don't recall the give-away distinctions between the two versions.  The one "hammer" — inexact because it was struck by one, not used as one — I used to own was for cold cutting.  Maybe the hole was provided to temporarily hold a "pin" to keep it from being driven inside, say, a barrel when one is removing one end of one?  Okay, go ahead and sneer or snort — I say that at times there's nothing wrong with blue-sky speculation.   *he quick carpes the diem and snorts @&w/ himself*
« Reply #13 on: June 04, 2014, 08:46:48 AM »
Hot cuts have slimmer blades; cold cuts are hefty to take being hammered into cold metal.  I use my little guy for hot cutting.  I can maybe see the hole holding a pin, but then, the thing would have had to go through the handle before the pin would do any good...
« Reply #14 on: June 04, 2014, 10:13:56 PM »
Creaser to form the crease when making horseshoes????, I base that on the size. Not enough mass or length to be a hot cut.
The hole is curious, though.
