Author Topic: Female inverted phillips head wrench ???  (Read 2254 times)
Offline Catfish
« on: March 28, 2014, 11:41:40 PM »
It's most likely a common wrench  , speaks Chinese to me....female inverted Phillips head  ...short as you can see...cast iron...never used...like the other small square wrench. No manufacture marks...came in the same box with the Charles miller socket set. thanks for any insight...
« Last Edit: March 31, 2014, 01:42:40 AM by Catfish »
Will find what was found, above the earth or in the ground. Catfish
Re: Female inverted phillips head wrench ???
« Reply #1 on: March 29, 2014, 08:02:38 AM »
For turning a wing nut?
« Reply #2 on: March 29, 2014, 09:57:50 AM »
It looks like a tank wrench. Could it be for some proprietary valve ? WAG
Offline Catfish
« Reply #3 on: March 29, 2014, 01:00:53 PM »
Well starring at  it more closely.... could it possibly be a square nut socket wrench ? with it being made from this Miller who made custom wrenches . Being a wrench for straight in ( like through a hole or shield ) tight nit spots were you can't get the other ( squared wrench in picture ) in from the side ?
« Reply #4 on: March 29, 2014, 01:37:08 PM »
Looks like a security wrench for some sort of spigot (tap/faucet - whatever term you use in the USA...)
