Author Topic: mystery to me....  (Read 3351 times)
Offline sdarmstrong
mystery to me....
« on: March 20, 2014, 03:30:24 PM »
Hi people !
Anybody any idea what this tool is for? Dont thonk its that old ?
Re: mystery to me....
« Reply #1 on: March 20, 2014, 07:14:28 PM »
Never seen one with all its parts before - mine just has the two blades... cannot find it, but believe it is called a Tek Tool (or something like that) - the name is usually stamped on the blade holder - it's a plough for cutting narrow grooves in wood - cuts on the push and pull - made c 1950's - 1960's..
I just can't spell - TEC tool see: http://www.ebay.co.uk/itm/TEC-TOOL-GROOVING-PLOUGH-VINTAGE-CUTTING-TOOL-/141038562670
« Last Edit: March 20, 2014, 07:28:59 PM by Billman49 »
« Reply #2 on: March 20, 2014, 09:23:50 PM »
Somewhere, I have an old ad for one from the late 1800s.  I think it was called a hand gaining tool.  I think the brand was Mathews, but I am out of town.
« Reply #3 on: March 21, 2014, 02:47:32 AM »
My PC playing up, cannot post an image - see: http://i56.photobucket.com/albums/g190/mirboo/Woodworker%20Scans/WoodworkerDecember1960d.jpg
From a 1960's Woodworker magazine - shows the maker as British..
« Last Edit: March 21, 2014, 08:32:38 AM by Papaw »
« Reply #4 on: March 21, 2014, 08:33:41 AM »
From Photobucket all you need to do is copy the IMG tag and paste it directly in the body of your post.
« Reply #5 on: March 21, 2014, 10:26:50 AM »
Thanks for that
Offline sdarmstrong
« Reply #6 on: March 24, 2014, 04:05:11 PM »
Thanks for all the help ! Anyone able to post up a copy of the user instructions as I really like to be able to use all of my old tools.
« Reply #7 on: March 25, 2014, 01:18:50 PM »
Using the TecTool Two-cutter Plough Plane. The Tectool cuts alternately in both directions and the shaving thickness is controlled by the angle the engaged cutter makes with the work. With the body of the tool kept parallel with the surface of the work a fine shaving is produced. A slight rocking motion will produce a thicker shaving. Heavy pressure should never be used. It is not necessary to remove the cutters from the frame for sharpening, but when changing cutters be sure the key is fully inserted in the head of the socket screw. the exact groove width required may be chosen by staggering the cutter (see illustration). Washers, paper, cardboard any kind of packaging can be used for offsetting the cutter to the exact distance required up to a full 3/16. Very wide grooves are cut in stages from left to right. The 1/16" cutters must always be seated on the washers provided otherwise they will dish and snap under pressure of the socket screws.
All these advantages over the old type Plough plane? 1 Works to a stop 2. Cuts any exact chosen groove width. 3. Grooves in a hollow. 4. Grooves around a bend. 5. Grooves on an angle. 6. Cuts dovetail housings. 7. Works against straight edge. 8. Grooves down 1/16" 9. Adaptable for cross grain grooving. 10. Variable shaving thickness control. 11. Long cutting edge life and resharpening without dismantling. 12. Reversible for left handed users. Manufactured by the Tectool MFG., Rainham Rd South Dagenham Essex.
No illustrations, source: http://www.worthpoint.com/worthopedia/vintage-woodworking-tool-tec-tool-312791258
« Last Edit: March 25, 2014, 01:40:10 PM by Billman49 »
Offline sdarmstrong
« Reply #9 on: March 26, 2014, 04:58:10 PM »
Thanks for that. A really great help !!
