Author Topic: Big Pierce Arrow wrench, made by Fairmount  (Read 4082 times)
Offline Wrenchmensch
« on: January 21, 2014, 01:29:11 PM »
I bought this wrench because of its Pierce Arrow logo stamp, its unusual configuration, and its low price.  The open end is 3 3/4 inches wide.  The closed hexagonal end is 1 1/2 inches across.  the wrench is just under 11 inches in length.
The wrench's steel is 1/8 inch thick, and the openings have 3/16 inch lips on the underside.  This wrench was designed to hold up, and not be distorted by use.
I would like to have some automotive expert opinions on the specific applications for this wrench.  Was the large end used on a Pierce truck's or automobile's exhaust manifold, or on one these vehicle's hub caps?  Did the smaller end tighten a gas cap nut, or something else?
Offline BRwrench
  • Ohio
Re: Big Pierce Arrow wrench, made by Fairmount
« Reply #2 on: January 21, 2014, 05:26:18 PM »
My guess is large end for hub cap and other end for spindle nut.
Offline strik9
« Reply #3 on: January 21, 2014, 07:32:55 PM »
For tightening the packing in the water pump shaft?
    Just another WAG but it is a common use for big, short wrenches.
« Reply #4 on: January 22, 2014, 10:02:21 AM »
about the same apparent size as the leftmost wrench in the toolkit in this photo: http://www.papawswrench.com/vboard/index.php?topic=198.0
Offline Bus
    • The Wrenchingnews
« Reply #5 on: January 22, 2014, 10:23:04 AM »
The wrench came with Pierce Arrow Models 80 and 81 from 1924 thru 1928. The big end was for the hubcaps. Don't know about the small end.
« Reply #6 on: January 22, 2014, 01:19:05 PM »
Bus:
Thanks for the information on the OE end of this wrench.  The thought about the closed end of the wrench being used for a gas cap derives from Jay Leno's description of a White 909 M wrench which he gave me.  He said his 1909 White Steam car has a threaded gas cap that is opened by using the OE of the White 909 M wrench.  The White 909M wrench's OE is 2 inches wide vs. the 1 1/2 inch width of the Pierce Arrow wrench's closed end.  It seems to me that my first cars from the late 1940s also had fill 1 1/2 inch pipe diameters.  Were gasoline fill pipe diameters standardized some time between 1909 and 1928?
« Last Edit: January 22, 2014, 01:47:29 PM by Wrenchmensch »
