Author Topic: Need help with a very unusual hand vise. SOLVED ALSO  (Read 7332 times)
Re: Need help with a very unusual hand vise. SOLVED ALSO
« Reply #15 on: January 10, 2014, 11:16:05 AM »
These were often supplied with a key for tightening, square hole one end for the ratchet, and a slot with a central round hole for the wing nut on the vice, at the other end.
« Reply #16 on: January 10, 2014, 11:25:13 AM »
No pictures, but a description of their use can be found at: http://www.samhallas.co.uk/repository/po_docs/h2_open_line_constn_2.pdf Pages 4 and 5
« Reply #17 on: January 10, 2014, 11:30:20 AM »
This one is still available new - from Jalandar, Punjab, India... The image shows the key...
Link: http://www.tradeindia.com/fp1422142/Draw-Vice.html
« Reply #18 on: January 10, 2014, 06:56:33 PM »
I don't think I'd want to wind that handle very long.  I liked the bronze one  on the one that was on Worth Point.
Thanks for the info.
« Reply #19 on: January 11, 2014, 03:12:52 AM »
Archiving some images, I found this
« Reply #20 on: January 11, 2014, 03:22:25 AM »
Just had a look at the Worthpoint image - I was wondering where the talk of a bronze handle came from... IMHO this not original to the vice - the ratchet was used to tension the line (using a different, probably stranded steel, cable) - to get the correct tension it would be necessary to have fine control over a relatively few turns (there is no space for a lot of wire on the ratchet spool). A lever would give better control than a handle of the type shown.. Some of the draw tongs have a spring scale incorportated to measure the tension, but I guess most linesmen could get this pretty right by measuring the sag on the wire....
The one below also availabe from India (Indiamart).... with the more usual type of handle...
« Last Edit: January 11, 2014, 03:24:13 AM by Billman49 »
« Reply #21 on: January 11, 2014, 03:31:59 AM »
William Wilkinson Shear manufacturer Grimesthorp Baine's 1822
William Wilkinson Shear & Makers Grimesthorpe Pigot's 1828-9
William Wilkinson Manufacturer of sheep, garden, horse and glovers' shears & shoe, cook, draw Grimesthorpe White's 1833
William Wilkinson (& Sons) manufacturers of sheep shears, shoe, bread & drawing knives, steel Spring Works, Grimesthorpe White's 1849
Rev. William Wilkinson (& Sons) sheep shear, shoeknife &c. manufacturers Grimesthorpe White's 1852
William Wilkinson (& Co.) sheep & garden shear &c. manufacturers 17 Backfields White's 1852
William Wilkinson (&Sons) manufacturers of sheep shears, shoe, bread & drawing knives, steels Spring Works, Grimesthorpe White's 1852
William Wilkinson (& Sons Ltd.) manufacturers of sheep shears &c Grimesthorpe Road Kelly's 1893
(also Frederick William Wilkinson Electro-plate manufacturer 57 Trafalgar Street Kelly's 1893)
William George Wilkinson Sheep shear manufacturer (W. W. & Son) h. 25 the Dale, Norton Woodseats White's 1911
William George Wilkinson Sheep shear maker (Wilkinson Walter & Son) h. 25 The Dale, Norton Woodseats White's 1919
William George Wilkinson Sheep shear manufacturer (W Wilkinson & Son) h. 25 The Dale, Norton Woodseats Kelly's 1925
William George jun. Wilkinson Sheep shear manufacturer (W Wilkinson & Son) h. 59 Hackthorn Road, Norton Woodseats Kelly's 1925
source: http://www.sheffieldhistory.co.uk/forums/index.php/topic/5460-william-wilkinson-sons/
plus another adverising image
see also:
Printed notices of the formation of Burgon and Wilkinson, Sheffield as a limited company  B & B 43  1895
List of plant and machinery at Burgon and Wilkinson's Spring works in Grimesthorpe, Sheffield and valuation by Arthur M. Wild of Sheffield  B & B 44  1898
Draft valuation of fittings and plant  B & B 45  1898
Draft valuation of finished and partly finished goods at Burgon and Wilkinson, Sheffield  B & B 46  1898
Draft valuation of stock, mostly hammers  B & B 47  1899
Assignment of Burgon and Wilkinson's trade-marks and goodwill to Burgon and Ball, with some other relevant deeds and copies of deeds  B & B 48  1899
Bundle of accounts in connection with the liquidation of Burgon and Wilkinson, Sheffield including a petty cash book and bundle of vouchers  B & B 49  1899
Printed particulars of sale with plan for Spring Works, Grimesthorpe, Sheffield former premises of Burgon and Wilkinson Ltd  B & B 50  1899
source: http://www.nationalarchives.gov.uk/A2A/records.aspx?cat=199-bb&cid=6-1#6-1
Note: Burgon & Ball (makers of sheep shears), and successors to William Wilkinson,  are still in existence in Sheffield
see: http://www.burgonandball.com/
