Author Topic: Unknown Die Head ? Thread Restorer ?  (Read 9222 times)
Re: Unknown Die Head ? Thread Restorer ?
« Reply #15 on: January 01, 2014, 05:03:21 PM »
(Threads per Inch?).
From across the pond, but might or might not be old enough to predate Whitworth (1841)
hmm...very interesting design.....
« Reply #16 on: January 02, 2014, 02:58:34 AM »
Small versions like this, with a finger hole in the body, were often used by clockmakers, lock makers etc for putting threads on studs that hold the bodies together... Hence the fine 24, 32 tpi...
« Reply #17 on: January 02, 2014, 07:56:13 AM »
I like it.  Haven't seen one quite like this, though I've seen them with a single handle.  Boker is a dependable hand tool and knife company.
Offline ouray19
« Reply #18 on: January 02, 2014, 04:57:02 PM »
The grunge is like oil and dirt that has been packed in around the die heads. Maybe also clean off some of the rust. When I read about soaking in vinegar in a glass bowl I just thought it might help make this tool look better. Is it necessary to use a glass bowl or would a plastic tub work? I also have a bunch of old wrenches with paint and rust that I would like to clean. Is vinegar OK? Thanks
Growing old is mandatory, growing up is optional.
« Reply #19 on: January 02, 2014, 05:20:44 PM »
Plastic is fine for vinegar, and you can throw it away later when it gets scummy
Vinegar won't take off paint...just dissolves a little metal and lets the rust fall off...
Offline ouray19
« Reply #20 on: January 03, 2014, 06:59:17 AM »
Thanks for your help. My wife locked all her good glass bowls in the cabinet and I'm not allowed to use them.........
Will give it a try this weekend and see what happens.
Thanks again, John.
