Very nice haul.
the square block dies come in handy in cases where a thread has to be cut in place, on an existing line, with limited room.
I have never used (or seen) a sqware die ratchet. I have always been forced to use a pipe wrench.
If that Toledo reamer comes apart, it should do so similiar to the die ratchet. Pull the ratchet pin, and set to 90 degrees to remove the head.
