Dimm witted any help with these would be appreciated, even a part number so I can order it if I have too, preferably brass. Thanks
Branson it would be the same diam as a hole puncher, are they all the same size, standard hole I thought and the longer the better, I can always cut it down if need be or I can just keep adding to the book.
I have seen the two and three pieces, one being the male, one being the female, ( insert male into female ) and the last piece may be the collar that slips over the male or female and is the same size as a standard hole puncher if you get my meaning. Thanks
