Tool Talk
What's-It Forum => What's-It Forum => Topic started by: skipskip on November 12, 2017, 10:28:46 AM
I have had a couple of these, no clue about their use.
this one is about a foot long and brass
too soft for a chisel
(https://farm5.staticflickr.com/4578/24492546398_39c00b112a_z.jpg) (https://flic.kr/p/DjjGJJ)DSCF7357 (https://flic.kr/p/DjjGJJ) by Skip Albright (https://www.flickr.com/photos/skipskip/), on Flickr
Another cobbler's tool??????
any signs of it being heated?
thinking maybe a special soldering iron, but the handle is really close to the heated part.
Soldering iron seems unlikely. There's no tinning on what would be the operating end. Shank is too short: you need some distance between the hot part and your hand.
Flame-heated soldering tools were traditionally made of copper - at least the common ones. Not sure if there were applications for brass tools where copper wasn't the right material.
That ridge on the brass end suggests a thumb rest. And that suggests leather work of some sort.
OTOH, I do not see anything similar here.
https://www.google.com/search?q=vintage+leather+working+tools&tbm=isch&tbs=rimg:Ce1aYX2IgjuCIjhgT_1LwRP-wuNnLkUwF8SsE3K9g4kTX5MiN1240DYTI-n9Tk3RmRvvftOSrkaf3xnUgNxuPV_1Mw9yoSCWBP8vBE_17C4ERaPre9YSjH0KhIJ2cuRTAXxKwQRk5VHYHrND9wqEgncr2DiRNfkyBFRsd2KhogInCoSCY3XbjQNhMj6EUMTDbK1FGIMKhIJf1OTdGZG-98RcW97D9VMX-sqEgm05KuRp_1fGdREAbJ6_1Kz3pBioSCSA3G49X8zD3EZGNakJVmWaX&tbo=u&sa=X&ved=0ahUKEwjTqOHq-7nXAhXk6YMKHXL5CY0Q9C8IHw&biw=1280&bih=570&dpr=1.25
i know bell system used a tool made of wood for swiping solder,could one be made of brass.,.WAG
Wax or some type of heat sealing of edges? brass body would hold the heat. tip could get into places others could not.
It's a door stop, may be, just a wag.
