Blacksmith and Metal Working Forum > Blacksmith and Metalworking Forum
Anvil Shaped Object
shortfuse:
If you can lay your hands on some fork lift tines, they will work as a beginner anvil. Cut the thickest parts into pieces about 14"-16" long, stack up about four or five pieces, bevel the gaps all around the edges and make deep pen welds. You can also mod a hay bale fork and weld it to one end for a horn. Our blacksmith group has a member who makes these and sells them for about $150 apiece. He uses one with his portable forge at our demos.
john k:
2 more places that I would check, large towing company, one in business for years. Probably got a welding table with lots of scrap bits. The other place would be a private dirt moving contractor, one with big bulldozers, scrapers and such. Oh, are there any small welding/repair shops around you? These would be my first look sees.
Mike H:
shortfuse-thanks for input,
fork lift tines are something that I hadn't even considered as
possible source for material
JohnK- likewise, appreciate input
we have one large towing outfit just a bit west of us,
will investigate
The ASO is a little further along
got some holes drilled in the bottom
to tie it down to a base, either log chunk
or laminated lumber. I put in a call to the
tree guy that comes out and trims the oak trees we have
to see if he has some log sections I could use as a barrier to
keep people from doing U-turns in my front yard. Might give him
another call to see if he has one piece that would work w/ the ASO.
Navigation
[0] Message Index
[*] Previous page
Go to full version
